Hello World example run error?
In reply to S.P.Rajkumar.V:
Hello Sir,
I properly set the UVM library home to …/uvm1.0p1/src . Infact I put all .sv files in the same folder so that there is no directory issue. But still its causing errors.
I am not aware of the total commands use to run any uvm example. I am reading some new stuff about DPI compiled libraries? I didnt understand it at all?
I am using questasim10.0b version on windows 7, 64 bit version. I thought the libraries are already built in and no need to complile them again. Please give me some guidance about this and for the proper commands to run the hello world example or any uvm example from the web.
Thanks for your reply,
Swapnil
