Hi Dave,
Thanks for replying. I have a test case extended from base test. Now in my test, I’ve generate the traffic as following way,
class base_test extends uvm_test;
super.run_phase();
phase.raise_objection(this);
// Created the sequence and start the sequencer
// For initial traffic generation
// Wait for completion of the traffic on the lanes
phase.drop_objection(this);
endtask : run_phase
endclass : base_test
class my_test extends base_test;
super.run_phase();
endtask : run_phase
endclass : my_test
I don’t know this is enough or not. The test case is hanging in uvm_phase.svh file as I mentioned earlier.
//OUTPUT
The total objection count is 1
Source Total
Count Count Object
0 1 uvm_top
1 1 uvm_test_top
UVM_INFO @5805485000 run_phase, after drop the objection in my_test
Source Total
Count Count Object
0 1 uvm_top
UVM_INFO @5805485000 TEST_DONE, 'run' phase is ready to proceed to the 'extract' phase
UVM_INFO @5805485000 PH/TRC/EXE/ALLDROP, Phase 'common.run' (id=121) PHASE EXIT ALL_DROPPED
UVM_INFO @5805485000 PH_READY_TO_END, Phase 'uvm.uvm_sched.post_shutdown' (id=332) PHASE READY TO END
UVM_INFO @5805485000 PH_READY_TO_END, Phase 'common.run' (id=121) PHASE READY TO END
I think uvm_top have one objection remains to drop as per the Total Count displaying in the log file. I don’t know what is this and how to drop that one, but the test is hanging 2-3 hrs after above display.
I have enabled the UVM_PHASE_TRACK verbosity in above log file.
Regards
