Given a 32 bit address field as a class member, write a constraint to generate a random value such that it always has 10 bits as 1 and no two bits next to each other should be 1. Please solve this I'm unable to proceed
class gen_rand;
  rand bit [31:0] value;
  constraint c1 { {$countones(value) ==10};
                 {value == s_addr(value)};
  function bit [31:0] s_addr(bit [31:0] r);
    value =r;
    //if(value[30]&value[31]==0);
    for (int i = 0; i < 31; i++);
     (!(value[i] && value[i + 1]));
  function void display();
    $display("value in binary = %0b",value);
    gen_rand gn =new();
    for (int i=0;i<5;i++)begin
      gn.c1.constraint_mode(0);
    gn.randomize();
      //gn.c1.constraint_mode(0);
      //gn.disable_constraint();
      gn.display();end
This isn’t working. I’m getting the errors
See this about using functions in constraints: Regarding function in constraints
Use an iterative foreach constraint instead of a for loop.
constraint c1 { $countones(value) == 10;
                foreach(value[i]) i>0 -> !(value[i] && value[i + 1]);
but I’m getting the output like this
value in binary = 11000011000111000101010100011
value in binary = 10101010101101110100011111010110
value in binary = 1011101111010100110110000000001
value in binary = 11011011110001000001011001001
value in binary = 110110011111000011000101101
Delete:
and change i+1 to i-1
Hi @dave_59 , I still getting the error even after doing all the changes
xmsim: *E,RNDCNSTE (./testbench.sv,9|60): Randomization constraint has this error, which will cause the randomize function to return 0 and no new rand values will be set:
Out of bounds index in array reference, index 32 is not in the range [31:31].
gn.randomize();
This works for me:
class gen_rand;
  constraint c1 {$countones(value) == 10;
                 foreach(value[i]) i>0 -> !(value[i] && value[i - 1]);
    $display("value in binary = %b",value);
  gen_rand gn =new();
  initial for (int i=0;i<5;i++) begin
    assert(gn.randomize());
    gn.display();
# value in binary = 10000100001001010010100001010100
# value in binary = 10010000101000010100101000010001
# value in binary = 01000010101000001010000010010101
# value in binary = 10010101000100100100101010000000
# value in binary = 01001001010100010010100100001000
Thanks dave, it’s working
Hi Dave
If we do not want to use countones, can we write as below?
value.sum(item) with (int’(item==1) == 10);
Regards
Jyoti
No, the array reduction methods, like sum() only work on the unpacked dimension of an array.
class packet;
  rand bit[31:0]a;
  constraint cp1{$countones(a)==10;
                 foreach(a[i])
                   if((a[i]==1) && i>0)
                     a[i]!=a[i-1];
module tb;
    packet p=new();
    p.randomize();
    foreach(p.a[i])
      $write("%0d ",p.a[i]);
