IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, November 8th at 3:00 AM US/Pacific.
Hi dave… i could not understand your implementation. My expectation is
if ( value inside {[0:3]})
data[45:14] = temp_data[31:0];
else if (value inside {[4:7]})
data[45:14] = temp_data[63:32];
else if (value inside {[56:59]})
data[45:14] = temp_data[479:448];
Thank you deve. it’s working.
may i know difference between below items temp_data[((i*32)+31):(i*32)] ---- > for this i got The range of the part select is illegal error temp_data[i*32+:32] ----> this is working fine
both are doing part selection. i could not understand the difference.
The difference has to do with the compilation flow. SystemVerilog is based on a fixed type system where the width of variable/expression is part its type. It needs the type to generate the right calculations for evaluating expressions. The compiler cannot calculate the width if either [lindex:rindex] includes a variable. The [pos+:width] syntax allows a variable, but the width still needs to be a constant expression.
