Hi all
i have a class called config which is of type uvm_component and i am setting it in the uvm_test → as we know which is of type uvm_component
now i wanted to get the config class to my uvm_sequence - how can i do it?
i know we cant get using config_db get method which is only for exchange between uvm_components
And the reason why i wanted to get config is → ill generate a packet say → `uvm_do_with(req,{req.payload.size() = config.abc(req.packet)); where packet is a variable in seq_item of type bit [2:0] packet and payload is a dynamic array in my seq_item and abcis a function in my config gives different sizes by doing some calculations basing on generated packet
Can anyone help?
