Generate unique elements in an array
As Dave mentioned, SV 2012 has this natively in the language. Make sure your tool supports it, if not start demanding it - now it is an approved standard (IEEE SA - IEEE 1800-2012)
In SV 2009 version you will need to use the foreach, perhaps you can do:
constraint data_values { foreach(data[i]) data[i+1] != data [i] ;}
A practical example is available at: Verification Course Blog | VeriLog Courses | CVC
Good Luck
Ajeetha, CVC
