I have coded coverage class but monitor is partially done. So can I prior check coverage before implementation of monitor, so that i can visualize bins hit. If yes, then how?
Anybody has idea then, pls help.
In reply to tech_savvy:
You can create a small environment with an analysis port, and connect that to an instance of your coverage collector class. Then send test transactions to your coverage collector.
Apart from this way, is there any other idea. I don’t want to use analysis port. I want to make coverage test class where I will randomize my packet and see bins hit.
