I have written functional coverage code where I have used option.per_instance,
I ran the code with the following scenarios,
- option.per_instance=0
- option.per_instance=1
- Not used option.per_instance
I am not able to make out any difference among the result of these scenarios and I am checking the result on my tool.
Could you tell me how to check?
In reply to Vinutha K R:
It won’t make any difference if you only have one instance of the covergroup, or if you are collecting identical coverage for each instance.
You may also find the information in this article useful, in terms of how coverage options effect the coverage model:
It won’t make any difference if you only have one instance of the covergroup, or if you are collecting identical coverage for each instance. [/quote]
If we have multiple instance of the covergroup, then will it effect coverage percentage?
In reply to LokeshBiradar:
Yes. per_instance = 1 is considered as different coverage instance.
