Fork Label Not Getting Disabled
Hi Everyone
// With Xcelium, we are observing fork with labels not getting disabled with disable <label>
  fork : check
      repeat(10) begin
      #1ns;
      $display("Done 1 at time = %0t", $time);
      repeat(5) begin
      #1ns;
      $display("Done 2 at time = %0t", $time);
  join_any
  disable check;
Output: Here the first begin/end if not getting killed
Done 1 at time = 1
Done 2 at time = 1
Done 1 at time = 2
Done 2 at time = 2
Done 1 at time = 3
Done 2 at time = 3
Done 1 at time = 4
Done 2 at time = 4
Done 1 at time = 5
Done 2 at time = 5
Done 1 at time = 6
Done 1 at time = 7
Done 1 at time = 8
Done 1 at time = 9
Done 1 at time = 10
Case 2 :
  fork : check
      repeat(10) begin
      #1ns;
      repeat(5) begin
      #1ns;
  join_any
  disable fork;
Output: Here the first begin/end is getting killed
Done 1 at time = 1
Done 2 at time = 1
Done 1 at time = 2
Done 2 at time = 2
Done 1 at time = 3
Done 2 at time = 3
Done 1 at time = 4
Done 2 at time = 4
Done 1 at time = 5
Done 2 at time = 5
If you run your code on EDA Playground, 3 of the 4 simulators will give you the results you are expecting, and one will not, possibly due to a tool issue.
This Siemens sponsored forum is not for tool issues. You should refer to your tool documentation or contact your tool vendor for additional assistance.
