In reply to marathuteja:
If you are just looking for the difference, I added a few more lines to your code to demonstrate it. I also added comments that may help.
module test();
task method(int ii);
#1 ; //I am adding a delay to highlight the difference.
$display("time = %0d; i = %0d", $time,ii);
task fork_1();
fork //The below is all a single thread.
for(int i= 0; i<4; i++)
method(i);
join_none;
task fork_2();
for ( int i= 0; i<4; i++) //There are 4 parallel thread here. You will see that all values being printed are i = 4. You will i to be "automatic" to fix that.
fork
method(i);
join_none;
$display("Calling fork_1");
fork_1();
#5; // Introducing a delay to move simulation time. Remove this to see how behaviour changes.
$display("Calling fork_2");
fork_2();
#1;
$display("The end");
Output :
xcelium> run
Calling fork_1
time = 1; i = 0
time = 2; i = 1
time = 3; i = 2
time = 4; i = 3
Calling fork_2
The end
time = 6; i = 4
time = 6; i = 4
time = 6; i = 4
time = 6; i = 4
xmsim: *W,RNQUIE: Simulation is complete.
xcelium> exit
