Hi Everyone,
I am trying to understand the below code w.r.t to $display. I know below code will result in 3 3 3 as output. My question is if I remove #0(before the $display) nothing gets printed. Why is this so? It should be related to systemverilog scheduler regions, but I am not clear why this is happening exactly.
program no_auto;
for(int j =0;j<3; j++)
$write(j);
join_none
#0 $display;
endprogram
Instead of using #0 display, we can use wait fork as well, right ?
The processes created by a fork/join_none
start when the parent process suspends or terminates. Your problem is you used a program
instead of a module
. Simulation finishes immediately when the initial process of a program
terminates.
We strongly recommend against using the program block in SystemVerilog.
I understood without #0 the simulation ends immediately. However, how adding a zero time delay helps in holding the simulation?
The initial
block in the program starts in the re-active region. #0
suspends the parent process (the initial
block process) into the re-inactive event region. Then the forked process start and terminate in the re-active region.
When the re-active region is empty, the simulation can move to the re-inactive region. This schedules the parent process to resume in the re-active region. Then the $display
executes and the process terminates, ending the simulation.
If you do this in a module, you can get rid of my “re-” prefixes and every works the same in the active and inactive regions. But you won’t need the #0
because the simulation ends when all regions are emptied, or an explicit call to $finish
