Below is my code for NUMLINES=4. If pkt_send_req comes on any of the requests, pkt_send_ack[i] must be asserted for once cycle within a delay of 1-32 cycles. I am not seeing the expected behavious. Total number of acks are not matching total number of reqs. Can you please correct this?
task foo_driver::drive_ack();
int req_pos;
int ack_pos;
int pos;
int delay_ack;
int req_pos_q[$];
int ack_q[$];
semaphore mutex = new(1); // Create a semaphore with 1 token
forever begin
@(posedge intf.clock);
begin: requests
if(|intf.pkt_send_req ==1) begin
val = intf.o_val;
for (int i = 0; i < `NUM_LINES; i++) begin
if (intf.pkt_send_req[i] == 1) begin
mutex.get(); // Acquire the mutex
req_pos_q.push_back(i);
mutex.put(); // Release the mutex
else begin
val = 0;
begin: acks
while (req_pos_q.size() != 0) begin
ack_pos = req_pos_q.pop_front();
ack_q.push_back(ack_pos);
delay_ack = $urandom_range(32, 1);
repeat (delay_ack) @(posedge intf.clock);
pos=ack_q.pop_front();
intf.pkt_send_ack[pos] <= 1'b1;
intf.pkt_send_ack[pos] <= 1'b0;
join_none
Since you don’t have all the code shown, it’s hard to debug this. We can’t see the results you are getting. The while (req_pos_q.size() != 0) loop is in a race with the for loop in the request process. Also, it would be much simpler to use a mailbox#(int) req_pos_q instead of a queue wrapped around semaphores.
The below code errors out randomly. It still does not generate equal number of acks for the reqs. Please help me fix this code.
int req_pos;
int ack_pos;
int pos;
int delay_ack;
mailbox req_mb = new();
mailbox ack_mb = new();
forever begin
begin: requests
val = intf.o_val;
automatic int k = i;
if (pkt_send_req[k] == 1) begin
req_pos_mb.put(k);
$display("req is here with k=%0d",k);
$display("req size is %0d",req_pos_mb.num());
else begin
val = 0;
begin:acks
if(req_pos_mb.num()>0) begin
req_pos_mb.get(req_pos); // Get the request position from the mailbox
ack_mb.put(req_pos);
ack_mb.get(req_pos);
intf.pkt_send_ack[req_pos] <= 1'b1;
intf.pkt_send_ack[req_pos] <= 1'b0;
join_none
The below line was causing acks to return out of order since delay for ack[0] was 10 and delay for ack[1] was 1. Hence I removed randomization and fixed the value of delay. The mailbox approach was the best solution. Thanks for your help!
T
