Hi Dave,
Very good idea.
Another method using $dist_normal(seed, mean, std);
By given range related config, then val will be a bath-tub curve in this range.
class A;
rand int norm;
// range config
int high = 100;
int low = 0;
int mean = 50;
int std = 20;
int val;
constraint c {
norm == normal(mean);
function int normal(int mean);
return $dist_normal($urandom(), mean, std);
if (norm inside {[low:high]}) begin
val = high - norm;
// val within designed range will be bath-tub
endclass : A
