I’ve been exploring the use of the “followed by” operator (#=#) and initially thought it would help with coverage by preventing false positives. However, when testing the code with coverage statements, I found that both #=# and |=> give the same coverage results! Here’s my code and the corresponding coverage statements:
My understanding:
b |=> c: If b is not 1 at the clock edge, it passes vacuously and still hits coverage.
b #=# c: If b is not 1 at the clock edge, it fails and misses coverage.
* `b |=> c`: If `b` is not `1` at the clock edge, it passes vacuously and still hits coverage.
[Ben] Yes, the property b |=> c passes vacuously TRUE,
and true is true, regardless of its color.
Thus, it hits coverage
* `b #=# c`: If `b` is not `1` at the clock edge, it fails and misses coverage
[Ben] b #=# c is saying sequence "b" if followed by property c. If b==0, the sequence b is not a match, thus the property b #=# c` is false, and it misses coverage.
wow , thanks it works not with -coverage in run options
i have another question please
c_followed_by : cover property (seq_a #=# b)
$info (“\033[32m [%0t] c_followed_by pass”,$time); else
$info (“\033[32m [%0t] c_followed_by fail”,$time);
why can not i use else statement in cover statement as assertions?
i think it was assertion not coverage , please check the link EDA Playground , it give miss count for assertions only not coverage
coverage still got the same problem
the coverage won’t display the miss of followed by , that was my question
you have two variables fw and mp , both are 1 in the end of the simulation :)
functional coverage is a measure of what functionalities or features of a design have been exercised in simulation.
Those properties were true, and thus were covered.
What “miss” are you talking about?
By “miss” you mean failures?
cover directives can only pass, they never fail. If you need to know about failure, use assert. That gives you coverage that is passed, as well as notifying you when it fails.
