A concurrent assertion starts a new thread every clock cycle regardless of what expressions appears in your property. That thread (also called an attempt) remains active until the property passes or fails. Ranges may cause additional threads to be forked off. In your example, a new thread starts every clock cycle, but vacuously passes when C is 0, so that attempt gets immediately terminated.
first_match() makes more sense when used on a subsequence of a larger sequence. It prevents backtracking when a match on the subsequence is found, but a later term in the sequence does not match
Let’s take a look at a slightly modified example below which adds B to complete sequence.
On cycle 1, C is 0. Both assertions vacuously pass. Both threads are done.
On cycle 2. C is 1. Both assertions have repetition 1 of C. Both assertions start 2 new threads: the next cycle looking for repetition 2 of C or looking for D. There are now 4 active threads that started on cycle 2.
On cycle 3. C is still one. A new set of 4 threads start on cycle 3, but the rest of this discussion focuses on the threads that started on cycle 2.
Here’s where things diverge with the first_match assertion. D is now 1, so that is a match for sequence SEQ_CD. The first_match(SEQ_CD) kills the thread looking (and would have found) repetition 2 of C, and prevents creating the thread looking for repetition 3 of C. The first_match assertion has only one thread that started on cycle 2 now looking for B in the next cycle. The normal assertion has 3 threads; looking in the next cycle for B, D, or repetition 3 of C.
On Cycle 4, B is 0. There is no match for the first_match assertion, so that is a vacuous pass. D is 0, but C is still 1, so that leaves one thread still active for the normal assertion looking for D in the next cycle. That thread eventually passes.
I’ll stop going into details; the point was to show you how first_match prevents a later match of a larger sequence.
module sequence_operators;
bit a_clk;
bit B,C,D,E;
initial repeat(50) #5 a_clk = ~ a_clk;
default clocking my_clk @(posedge a_clk);
endclocking
$dumpfile("waveform.vcd");
$dumpvars;
@(negedge a_clk); {B,C,D,E} <= 4'b0_1_0_0;
@(negedge a_clk); {B,C,D,E} <= 4'b0_1_1_0;
@(negedge a_clk); {B,C,D,E} <= 4'b1_1_0_1;
sequence SEQ_CD;
C[*1:3] ##1 D;
endsequence
property FM_prop;
first_match(SEQ_CD) ## 1 B |=> E;
property normal_prop;
SEQ_CD ##1 B |=> E;
first_matchh : assert property(FM_prop)
$info ("\033[32m first_match assertion passed @%0t", $time);
$error ("\033[31m first_match assertion failed @%0t", $time);
normal : assert property(normal_prop)
$info ("\033[32m normal assertion passed @%0t", $time);
$error ("\033[31m normal failed @%0t", $time);
