I am performing a factory override in the my test using set_type_override. I am overriding a driver with a new driver extended from the old driver, similar to the following:
my_test extends uvm_test;
`uvm_component_utils(my_test)
// set factory override
old_driver#(<paramters>)::type_id::set_type_override(new_driver#(<parameters>)::get_type());
endfunction : build_phase
function void end_of_elaboration_phase(uvm_phase phase);
factory.print();
However, the simulation log shows the factory override did not work:
#### Factory Configuration (*)
# No instance overrides are registered with this factory
# Type Overrides:
# Requested Type Override Type
# <unknown> <unknown>
Is there a correct phase the factory information should be printed?
