In reply to Manirama:
You are facing issue in scorebaord because every time the same object is sent from monitor to SB. In SB before the value is retrieved from transaction object, monitor is changing the value.
Hence in the monitor every time create the new transaction object to collect the data & send it to SB. I have modified the code & running the test for multiple write & read and output is proper now. You can refer the code
Regards,
Shanthi
www.maven-silicon.com
