Extend task: main_phase in extended test class, members of the base task are not visiable
In reply to Michael54:
main_drain_time is not a member of the base_test class, it is a local automatic variable of the method base_test::main_phase. You cannot access automatic variables from outside the scope of their declaration.
You probably want to move the declaration of main_drain_time into the base class.
