Execution of connect phase twice in simulation
Hi
“If you want to modify connections in your environment (testbench) you can define a new test doing this” What do you mean by creating new test? do you mean that for only this test i have add layer/component between monitor and scoreboard to control the write operations? for rest monitor-scoreboard connection should remains direct?
But still the question is the same. can i disconnect existing connection in uvm?
Thanks
Mitesh Patel
