IMPORTANT NOTICE: Please be advised that the Verification Academy Forums will be offline for scheduled maintenance on Sunday, November 8th at 3:00 AM US/Pacific.
begin : thread1;
#100;
// do thread1 stuff
end : thread1;
//Process-2
begin : thread2;
#200;
// do thread1 stuff
end : thread2;
join_any
$display($time,"Done with fork join any");
The above code finishes the join_any at time zero. See if one of you smarties spots why.
Spoiler :: It would really be great if there was a warning or something on an empty statement in a fork join any! I felt like I was being punished for being HDL bi-lingual. It’s probably not a mistake you make if you only do verilog.
Here, the System Verilog code uses a fork join_any construct, but it completes at time 0 because the thread1 block contains an empty statement (;) after its label, causing it to finish immediately. The thread2 block, while scheduled to run for 200 time units, doesn’t affect the join_any since it waits for the first thread to complete, which is thread1 at time 0. This issue arises from a subtle syntax error—System Verilog allows an empty statement after a named block.
In SystemVerilog, the fork-join_any blocks the parent thread until any one of the spawned thread/process completes. As soon as any thread/process completes, the parent thread will continue execution following the fork-block.
In your case, two threads are spawned and having a delay statement. Along with this, you have named the thread by putting a label for begin-end blocks. I tried two variations of your code as follows along with the result and analysis: 1st Case:
begin: thread1;
#100;
begin: thread2;
#200;
join_any
$display("%0t: Done with fork join any", $time);
Output:
The output as expected, the parent thread continues as soon as "thread1" is completed because it is having less delay than "thread2", and executes $display present after the fork-join_any.
100: Done with fork join any
============================== 2nd Case:
begin: thread1;
#100;
end : thread1;
begin: thread2;
#200;
end // No label at the end
join_any
Output:
In this case, the output is not as expected. I think the label used at the end of 1st begin-end block is creating a problem and considering a "null" statement after the semicolon and fork-join_any completes without running actual thread.
