Error-[ICTTFC] Incompatible complex type usage
Hi, I am getting this error in my code - Dual port Ram Basic . Can someone let me know the possible cause. I am getting 3 Errors of the same kind but explaining the cause for only this one will help.
Error -
driver.svh, 20
Incompatible complex type usage in task or function call.
The following expression is incompatible with the formal parameter of the
task. The type of the actual is ‘class dpr_pkg::dpr_sequence_item’, while
the type of the formal is ‘class uvm_pkg::uvm_sequence_item’. Expression:
trans_d
Source info:
uvm_pkg::\uvm_seq_item_pull_port#(uvm_pkg::uvm_sequence_item,uvm_pkg::uvm_sequence_item)::get_next_item
(this.seq_item_port, trans_d);
Your driver needs to be parameterized with the appropriate sequence item.
