In reply to taihaichen:
The problem/solution is the same as in the other post you mention. The generate-for loop does not create true arrays that can be indexed with a dynamically changing variable. You must use constants or another generate-for loop to access reg_array. I would move the procedural-for loop into a generate for loop.
for (genvar stage_index_=0; stage_index_<REG_COL_NUM; stage_index_++) begin
always_ff @(posedge clk, negedge nreset)
if (~nreset)
reg_array[stage_index_].reg_col[0] <= 0;
