Hi
I need to be able to enter an array of real numbers as parameters to my SV code.
I can provide the number of elements as well. What would be the best way to do this?
I can think of at least two options
- write a script converting the array to SystemVerilog syntax
- use $fscanf
Thanks Dave. Could you please make an example of what you have in mind?
Suppose you have this list of real numbers
list_reals.txt
0.1
2.3
4.5
6.7
8.9
Then you could write a script to convert that list to SystemVerilog
const real array_of_reals[] = {
0.1,
2.3,
4.5,
6.7,
8.9
And then `include "list_reals.sv"
that file into your source code where needed.
To use $fscanf
int FD;
int num_elements,code;
real array_of_reals[];
FD = $fopen("list_reals.txt","r");
if($value$plusargs("num_elements=%d",num_elements) && num_elements > 0) ;
else $fatal(0, "num_elements not set");
array_of_reals = new[num_elements];
foreach(array_of_reals[i]) begin
if ($fscanf(FD, "%g",array_of_reals[i]) != 1) $fatal(0,"not enough elements to read");
$display("array_of_reals[%0d] = %g", i, array_of_reals[i]);
Instead of using $value$plusargs, you could also put the number of elements as the first number in the file.
