Driving Individual Pins
Hi, Is there a way to drive individual pins on the DUT instead of
  super.run_phase(phase);
  phase.raise_objection(this);
  #20
  drv_a=drv_a_seq::type_id::create("drv_a");
  drv_b=drv_b_seq::type_id::create("drv_b");
  drv_a.randomize() with {a inside {[10:10]}; };
  drv_b.randomize() with {b inside {[20:20]}; };
  drv_a.start(env_i.agt.seqr);
  drv_b.start(env_i.agt.seqr);
  #50;
  phase.drop_objection(this);
My TB Below:
`timescale 1ns/1ns
`include “uvm_macros.svh”
import uvm_pkg::*;
///////////////////////////////// Sequence Item ////////////////////////////
class seq_item extends uvm_sequence_item;
rand int data_in;
string name;
function new(input string path = "data_in");
  super.new(path);
`uvm_object_utils_begin(seq_item);
`uvm_field_int(data_in,UVM_DEFAULT)
`uvm_field_string(name,UVM_DEFAULT)
`uvm_object_utils_end
///////////////////////////////// Sequencer ////////////////////////////////
class reset_seqr extends uvm_sequencer #(seq_item);
`uvm_component_utils_begin(reset_seqr);
`uvm_component_utils_end;
function new(input string path = "reset_seqr", uvm_component parent = null);
  super.new(path,parent);
///////////////////////////////// Sequence /////////////////////////////////
class drv_a_seq extends uvm_sequence;
rand int a;
`uvm_object_utils_begin(drv_a_seq);
  `uvm_field_int(a,UVM_DEFAULT);
function new(input string path = "drv_a");
  super.new(path);
virtual task body();
  reset_seqr intf_seqr;
  seq_item seq_item_i;
  intf_seqr = p_sequencer.pick_sequencer("reset_seqr");
  `uvm_do_on_with(seq_item_i,intf_seqr,{name == "a"; data_in == a;})
class drv_b_seq extends uvm_sequence;
rand int b;
`uvm_object_utils_begin(drv_b_seq);
  `uvm_field_int(b,UVM_DEFAULT)
function new(input string path = "drv_b");
  super.new(path);
  `uvm_do_on_with(seq_item_i,intf_seqr,{name == "b"; data_in == b;})
///////////////////////////////// Driver ////////////////////////////////////
class driver extends uvm_driver;
  seq_item seq_item;
  virtual half_adder_if ha_if;
  `uvm_component_utils(driver);
  function new(input string path = "driver", uvm_component parent = null);
    super.build_phase(phase);
      if(!uvm_config_db #(virtual half_adder_if)::get(this,"","ha_if",ha_if))
      `uvm_fatal("DRV","Unable to get an interface handle");
    forever begin
      seq_item_port.get_next_item(seq_item);
      case(seq_item.name)
        "a": begin
           ha_if.a <= seq_item.data_in;
           `uvm_info("DRV",$sformatf("Transaction Sent To DUT Pin=%0s, Data=%0d",seq_item.name,seq_item.data_in),UVM_NONE);
        "b": begin
           ha_if.b <= seq_item.data_in;
      endcase
      seq_item_port.item_done();
      #10;
///////////////////////////////// Agent /////////////////////////////////////
class agent extends uvm_agent;
`uvm_component_utils(agent);
reset_seqr seqr;
driver drv;
function new(input string path = "agent", uvm_component parent = null);
  drv = driver::type_id::create("drv",this);
  seqr = reset_seqr::type_id::create("seqr",this);
virtual function void connect_phase(uvm_phase phase);
  super.connect_phase(phase);
  drv.seq_item_port.connect(seqr.seq_item_export);
///////////////////////////////// Env ///////////////////////////////////////
class env extends uvm_env;
`uvm_component_utils(env);
function new(input string path = "env", uvm_component parent = null);
agent agt;
  agt = agent::type_id::create("agt",this);
///////////////////////////////// Test //////////////////////////////////////
class test extends uvm_test;
`uvm_component_utils(test);
function new(input string path = "test", uvm_component parent = null);
drv_a_seq drv_a;
drv_b_seq drv_b;
env env_i;
  env_i = env::type_id::create("env_i",this);
  #20
  `uvm_do_with(drv_a,{a == 10;});
  `uvm_do_with(drv_b,{b == 20;});
  #50;
///////////////////////////////// TB TOP ////////////////////////////////////
module tb_top();
half_adder_if ha_if();
half_adder dut(
  .a (ha_if.a),
  .b (ha_if.b),
  .sum (ha_if.sum)
  $dumpfile("dump.vcd");
  $dumpvars;
  uvm_config_db #(virtual half_adder_if)::set(null,"uvm_test_top.env_i.agt.*","ha_if",ha_if);
  run_test("test");
Can you explain what you mean by “drive individual pins on the DUT”?
In UVM, a driver will translate sequence items into pin-level transactions. You don’t control individual pins.
There are other methodologies you can use which will allow you to control individual pins, but UVM is not appropriate for this.
Instead of task run_phase(uvm_phase phase);
#20
drv_a=drv_a_seq::type_id::create(“drv_a”);
drv_b=drv_b_seq::type_id::create(“drv_b”);
#50;
I would like to do
#20
uvm_do_with(drv_a,{a == 10;}); uvm_do_with(drv_b,{b == 20;});
#50;
This is more cleaner way of driving instead of creating, randomizing and starting the sequencer.
Using the `uvm_do_* macros is not recommended, as it removes some of the controls that you may want to do with your sequences.
Using create/randomize/start gives better control and is the recommended approach.
Hi Charles,
Could you please elaborate which other methodologies aside of UVM could be used for it?
