Driver , Sequencer N Sequence Parameterization
Hi Dave ,
Yes I got that part . To have Type Compatibility between the seq_item_port N seq_item_export Connection the Type Parameters must match.
Hence the driver N sequencer have same type Parameterization.
But the uvm_sequence is parameterized to same user_seq_item as well.
I didn’t get this part . What if the user_sequence doesn’t have same parameterization ?
( Since the sequence N sequencer aren’t connected via TLM Connections in driver N sequencer )
