Hi,
I still didn’t understand it that well.Below is the full class. You can see that adc_dac_env is the instance that has num_tx_lanes and num_rx_lanes. I called create to build it and then I am trying to read these variables.
class er_j204_example_tb extends uvm_test;
`uvm_component_utils(er_j204_example_tb)
// UVC environment
er_j204_env adc_dac_env;
// Constructor
function new(string name = "er_j204_example_tb",
uvm_component parent=null);
super.new(name,parent);
endfunction : new
super.build_phase(phase);
uvm_config_db#(int)::set(this,"adc_dac_env",
"num_tx_lanes", 3);
"num_rx_lanes", 5);
$display("NUMBER of tx and rx lanes are set here HELLO");
// create UVC top environment
adc_dac_env = er_j204_env::type_id::create("adc_dac_env", this);
$display("Num of tx lanes %0d", adc_dac_env.num_tx_lanes);
$display("Num of rx lanes %0d", adc_dac_env.num_rx_lanes);
endfunction : build_phase
endclass : er_j204_example_tb
