In reply to DigvijayS:
Hi Vijay,
In the above code if I declare int m without automatic keyword before it, then my compiler results to error. Can you explain why it is so.
From LRM-3.1a
join_none - The parent process continues to execute concurrently with all the processes spawned by the fork. The spawned processes do not start executing until the parent thread executes a blocking statement.
but the below code is providing the different result:
Code:
module fork_join_none();
int a,b,c;
a=5;
fork
a=6;
join_none
$display(“value of A before blocking stmt a=%d”,a);
b=0; //blocking statement
$display(“value of A after blocking stmt a=%d”,a);
endmodule : fork_join_none
Result:
value of A before blocking stmt a= 5
value of A after blocking stmt a= 5
Thanks & Regards,
Shriramvaraprasad B.
