I have some bins that I want to be illegal depending on a parameter
I have written this:
bins mode_a = {3'b100};
illegal_bins no_a = {3'b100} iff (DISABLE);
Those bins work as expected. If DISABLE is true, no_a overrules mode_a and make mode_a an illegal bin. If DISABLE is false, no_a doesn’t overrule mode_a so mode_a is a valid bin.
I am trying to do the same with transitional bins:
bins mode_a_b = (3'b100 => 3'b110);
illegal_bins no_a_b = (3'b100 => 3'b110) iff (DISABLE);
This does not do the same thing. Regardless of whether DISABLE is true or not, no_a_b overrules mode_a_b and makes it illegal.
Any suggestions?
In reply to Cmdr_Vimes:
The iff clause is not be used to specify bin creation. It only affects which bins are hit during each sample by evaluating a guard expression each time the sample occurs.
illegal_bins no_a = {3'b100} with (DISABLE);
The with clause gets evaluated when the covergroup gets constructed.
Unfortunately, transition bins have very limited functionality in SystemVerilog and you might be better off covering a sequence instead of using a covergroup.
In my case DISABLE is a parameter.
does not compile and I get an error.
In the method I’m using (iff), both coverpoints get triggered but the illegal_bin only get triggered if the iff is true, so the value goes into the illegal_bin and the normal bin then becomes an illegal_bin. Is there a specific reason that it doesn’t do the same for transition bins or is it just the limited functionality?
I get a warning about the mode_a or no_a bin being removed, depending on the value of DISABLE, no compiler errors. It’s possible you are using a version of a tool that does not support it yet. This was an 1800-2012 feature.
There are many problems with the specification of transition bins in the LRM. Here is one of them. So I would stick with something simple, otherwise use a sequence or build your own state machine.
