Disable UVM_WARNING from getting printed
I wanted to know how I can disable the UVM_WARNING message to be printed to the log?
Few options:
  1. Command line argument:
    uvm_cmdline_processor
    Example:
    +uvm_set_action=uvm_test_top.env0.*,ALL,UVM_ERROR,UVM_NO_ACTION
  2. Using: set_report_severity_id_override
    https://verificationacademy.com/verification-methodology-reference/uvm/src/base/uvm_report_object.svh
    Example:
    uvm_root::get().set_report_severity_id_override(UVM_WARNING,“my_test”,UVM_INFO);
  3. Using the uvm_report_catcher to tweak the severity of the messages:
    uvm_report_catcher
Thank you! I was able to suppress the warnings.
You are welcome.
Which option did you use eventually?
I used the second option-
base_class_obj.set_report_severity_id_override(UVM_WARNING,“my_test”,UVM_INFO);
