Disable fork killing non current process threads
  initial begin:i1
    fork:f3
      #10 $display("pkt_interrupt handler");
    join_none
    $display("getting the packet");
    t1();
  task t1();
      begin:a1
        #1 $display("get preamble");
      begin:a2
        #2 $display("get header");
    join_none
      begin:a3
        #5 $display("get payload");
      begin:a4
        #6 $display("get packet_timeout");
      join_any
    disable fork;
      $display("Processing packet");
This code prints
# getting the packet
# get preamble
# get header
# get payload
# Processing packet
Why is the disable fork killing the fork f3 as well? Shouldn’t it only disable the threads spawned by the process which executed disable fork which is task t1()?
The disable fork statement kills all child processes of the parent process executing the statement. A task/function call does not create a new process.
You need to add another fork process to prevent from killing f3 fork process.
  initial begin:i1
    fork:f3
    join_none
    fork : guard_fork  // <=======
      t1();
    join               // <=======
Refer to the following link.
Can we also give a name to each of the fork, and disable only the intended fork by calling its name?
Ex: fork: ABC
join_none
disable ABC;
That works sometines. The problem with disabling by name is that the scope name of the block is static. If there are many activations of the task, or in a loop, the disable applies to all activations.
