Difference in output using 'within' V/S 'intersect' operator
Thanks Ben.
(1) I was trying to use same logic (with different equivalent expression) for ‘intersect’ operator .
The consequent begins evaluation at time:35. 1st grant is true at time:85 and 2nd grant is true at time:125
 $rose(gnt)[=1] is equivalent to !$rose(gnt)[*0:$] ##1 $rose(gnt) ##1 !$rose(gnt)[*0:$] ,
 // Since !$rose(gnt) is true from t:35 to t:75, i.e !$rose(gnt)[*5] is true in our case
 // One of the possible LHS sequence is :
    ( !$rose(gnt)[*5] ##1 $rose(gnt) ##1 !$rose(gnt)[*0:$] )
//  Which can be further expanded to
    ( !$rose(gnt)[*5] ##1 $rose(gnt) ##1 !$rose(gnt)[*0] ) or  // 1st seq
    ( !$rose(gnt)[*5] ##1 $rose(gnt) ##1 !$rose(gnt)[*1] ) or
    ( !$rose(gnt)[*5] ##1 $rose(gnt) ##1 !$rose(gnt)[*N] )
 //  1st  seq  has an empty sequence !$rose(gnt)[*0] , hence it can be re-written as
    ( !$rose(gnt)[*5] ##1 $rose(gnt) ##0 `true )  // 1st seq
So why does assertion fail when 2nd grant is received ? Shouldn’t the single $rose(gnt) be sufficient for the LHS sequence to be a match ?
(2) In your equivalent expression I believe you have missed out on ##1
1)  (seq1 within seq2) is equivalent to: ((1[*0:$] ##1 seq1 ##1 1[*0:$]) intersect seq2 )
2)  $rose(gnt)[=1] is equivalent to !$rose(gnt)[*0:$] ##1 $rose(gnt) ##1 !$rose(gnt)[*0:$] ,
// expanding $rose(gnt)[=1] within $rose(req)[->1])
 (1[*0:$] ##1 !$rose(gnt)[*0:$] // ##1 added
   ##1 $rose(gnt) ##1 !$rose(gnt)[*0:$] ##1 1[*0:$]) intersect $rose(req)[->1]
