In reply to vineet_sharma:
The first recommendation is to not use the `uvm_field_XXX macros.
Second, cacheline_state is an array of enums. You most likely want to iterate over each item to print the name.
// Implementation example:
function string convert2string();
string s;
s = super.convert2string();
// Note the use of \t (tab) and \n (newline) to format the data in columns
// The enumerated cacheline_state types .name() method returns a string corresponding to its value
foreach(cacheline_state[i]) begin
$sformat(s, "%s cacheline_state[%0d] \t%s\n", s, i, cacheline_state[i].name());
return s;
endfunction: convert2string
function void do_print(uvm_printer printer);
printer.m_string = convert2string();
endfunction: do_print
