Hi All,
I was trying to write a constraint for following intention
For an unpacked array of size 4, 2 elements should be unique
Here is my attempt
class my_class;
rand bit [1:0] a[4];
rand bit [1:0] b;
constraint SUM {
// Constraints 'b' twice but doesn't constraint other 2 elements as unique !!
a.sum() with ( int'(item == b) ) == 2;
// Trial1 :: Works !!
foreach(a[i])
if( a[i] != b )
a.sum() with ( int'(item == a[i]) ) == 1;
// Trial2 :: Moved the if condition within with clause
foreach(a[i])
a.sum() with ( (a[i] != b) ? int'(item == a[i]) : 0 ) == 1;
constraint B {
b inside {a};
I observe that Trial1 works whereas Trial2 doesn’t
(1) I am not clear why randomization fails for Trial2. Any suggestions ?
(2) Is it possible to meet the intention without any helper variable ?
