I’m trying to create an array of objects to iterate through of my test bench. It looks something like this
jtag_chain#(CAP_MEMORY_REG_WIDTH ) cap_memory = new(.ir_ctl(CAP_MEMORY_CTL));
jtag_chain#(PSM_MEM_REG_WIDTH ) psm_mem = new(.ir_ctl(PSM_MEM_CTL ));
jtag_chain all_chains[2] = {cap_memory, psm_mem};
for(int i = 0; i < 2; i = i + 1) begin
all_chains[i].do_something();
However, running this in Questa I’m getting a
** Fatal: (vsim-13144) Illegal literal initialization.
Is there a better recommendation to implement this same sort of behavior?
Since each specialization of a parameterized class is a unique type, you need to create a common base class
virtual class jtag_chain_base;
pure virtual function void do_something();
class jtag_base #(int WIDTH) extends jtag_chain_base;
virtual function void do_something;
jtag_chain_base all_chains[2] = {cap_memory, psm_mem};
Note that you will only be able to access virtual methods defined in jtag_chain_base
or other members of its super class if you define jtag_chain_base
as an extension of another class.
