How we create a coverage model for an array for following problem statement?
I have a 32 bit sized array of depth 1024. I want to check for the array elements from 0 to 767 that bins are covering values 100-2023. Array elements from 768-999 are illegal to access.
Rest of the elemental access must be excluded from coverage.
There is no sample timing in what you described. And you only have 768 elements. How are they supposed to be spread over 1924 values? If I were to model exactly what you wrote:
bit [31:0] array[1024];
covergroup cg with function sample(bit[31:0] element);
coverpoint cp {bins b[1924] = { [100:2023] }; }
endgroup
cg cg_inst = new;
for(int i=0;i<768;i++). cg_inst.sample(array[i]);
Lets say the sampling happens at rising edge of each clock.
You have covered the problem of covering array elements from 0 to 767.
But the solution does not include other part of the problem statement, i.e. mentioning elements at indices from 768 to 999 as illegal in coverage model.
So far you’ve only told me that you have an array, and I’ve shown you how to cover values in the elements inside that array. I have no idea how you access each element unless you explain the protocols used to access that array. How is an illegal access supposed to be represented?
In any case using a covergroup is not the best place to check for illegal behavior. You should be using assertions or something like that.
