Hi All,
I have signal a,b,c. After a fell to zero, b &c will be true for two times at some cycles.
here is cover property ,
cover ($fell(a)[->1] ##1 (b&c)[->2])
is it correct?
thank you
Hi All,
is it correct?
thank you
cover property (@(posedge clk) $fell(a)##1 (b&&c)[->2]); // updated
// you need the cover property because it is concurrent.
// Use the logical && Operator instead of the bitwise & Operator
// It is best practice because it is more readable
Hi Ben,
Thanks for reply. How to detect if b&&c happen over two times, and report fail?
cover property ($fell(a) ##1 (b&&c)[->2]);
// you don't need that first goto, my error.
// 2) if you want to fire the cover once
initial cover property ($fell(a)[->1] ##1 (b&&c)[->2]) ;
// 3) on detecting no 3rd b&c
initial assert property ($fell(a)[->1] ##1 (b&&c)[->2] |-> always(not (b&&c)) );
Thanks for reply. I am sorry that I miss some information
signal A is a level signal and it will fell for few times, and b&&c can not happen over 2 times before next $rose(a). Also, b&c can not assert if no $fell(a) happen before.
assert property ($fell(a)[->1] ##1 (b&&c)[->2] |-> not ( (b&&c) throughout $rose(A) ) );
assert property (b&&c |-> $past($fell(a)...... // not know how to detect b&c can not assert if no $fell(a) happen before
For b&&c can not happen over 2 times before next $rose(a), the property is correct?
I do not know how to detect b&c can not assert if $fell(a) never happen before
Thank you
/* signal A is a level signal and it will fell for few times, and b&&c can not happen
over 2 times before next $rise(a). Also, b&c can not assert if no $fell(a) happen before.
assert property ($fell(a)[->1] ##1 (b&&c)[->2] |-> not ( (b&&c) throughout $rise(A) ) );
For b&&c can not happen over 2 times before next $rise(a), the property is correct?
I do not know how to detect b&c can not assert if $fell(a) never happen before */
module m;
bit clk, a, b, c;
// b&c can not assert if ! $fell(a)
bit a_fell=0;
always_ff @(posedge clk) begin
if($fell(a)) a_fell <=1;
// Note, depending upon your requitrements, you can asjest this support variable
if($rose(a)) a_fell <=0; // Check if this is what is needed
assert property(@(posedge clk) b&&c |-> !a_fell);
// signal A is a level signal and it will fell for few times, and b&&c can not happen
// over 2 times before next $rise(a)
assert property (@(posedge clk) $fell(a)[->1] ##1 (b&&c)[->2] |->
($rose(a)) or ##1 ( !(b&&c) throughout $rose(a)[->1] ) );
// 1) The "not" is a property operator; it cannot be combined with a sequential "throughout operator"
// You cannot use the |-> with an immediate test of !(b&&c).
// To solve this, I delayed the throughout by 1 cycle, and in the immedate cycle
// tested for a rose(a)
// Instead of throughout you can use its expanded version
($rose(a)) or ##1 ( !(b&&c)[*1:$] intersect $rose(a)[->1] ) );
thanks for reply
As for using throughout and intersect, which one is better practice?
Q: As for using throughout and intersect, which one is better practice?
A: First the syntax and its meaning per 1800
expression_or_dist throughout sequence_expr
The construct exp throughout seq is an abbreviation for the following:
(exp) [*0:$] intersect seq
[Ben] The intersect is only an abbreviation, in processing (simulation or FV) it is actually expanded to the intersect version; thus, there is no performance impact.
I prefer the use of the intersect insead of its abbreviation because:
1) If I use the throughout, I then have to go thru a mental jiggle to reconstruct its meaning. In fact, you made that very point in your coding of:
where you missunderstood its definition and missed the definition of the sequence $rose(A)[->1].
2) I come from a hardware design background and for me, the intersect is more visual.
Here I see a possible set of threads (the exp[*0:$]) instersecting (or crossing) a fixed sequence (the $rose(A)[->1]).
One more comment: In your initital posting you missed to specify many requirements.
An advice: I strongly believe in the use of AI, like perplexity, to check and expressing requirements, creating SV/SVA RTL and TB code. Yes, AI is not quite there yet, but the structures and information it brings help better express what is needed in the design and verification.
I used perplexity in writing my paper (link below) to address the requirements and even fixing my English composition.
The Traditional Req/Ack Handshake, It’s More Complicated Than You Think!
Hi Ben
Do you see any problem in writing this as
cover property ($fell(a) |-> (b&&c)[->2]);
Regards
Jyoti
Looks OK syntacticly
Thanks, hopefully covers the condition also?
May want to use this instead
cover sequence ($fell(a) ##0 (b&&c)[->2]);
No vacuity here.
