I am trying to accomplish the below using constraints:
No. of 1s should be followed by atleast same num of 0s.
// example:: 010110011100010, 111100001100100, 011000111000010
Any advice?
Any advice?
What have you tried? What works? What doesn’t work? If you post an example on EDA Plaground, others can provide assistance.
class pattern;
parameter int N = 64;
bit [N-1:0] data;
rand int count;
rand int unsigned zeros[], ones[];
constraint c1 {
count inside {[10:20]};
ones.size() == count;
zeros.size() == count;
zeros.sum() + ones.sum() == N;
constraint c2 {
foreach(ones[i]) { ones[i] inside {[1:10]}; }
foreach(zeros[i]) { zeros[i] inside {[1:10]}; }
foreach(zeros[i]) { zeros[i] >= ones[i]; }
int n;
foreach(ones[i]) begin
repeat(ones[i]) data[N-n++] = 1'b1;
repeat(zeros[i]) data[N-n++] = 1'b0;
Output:
0101010101010111111111000000000010101011111110000000101001010100
0100111111111000000000101001010101010110011111110000000100000000
0011110000110011001011111111000000001010000011100011100010101000
0101100000001000000100010100001010101110001010111111100000000000
0100000010100000010110000010101010100000000001011111000001010100
