Constraint Solver error
I am unable to figure out what is wrong with following constraint. I get - Error-[CNST-CIF] Constraints inconsistency failure
class fin_array;
  rand bit[31:0] N[10];
  constraint c_N {
    foreach (N[i]){
      if (i >0)
         N[i] == i;
        N[i+1] == i;
        //i == i +2 ;
N[i+1] tries to access invalid Index ‘32’
Try using
foreach (N[i]){
  if ( i inside{[1:30] )
     N[i] == i;
    N[i+1] == i;
    //i == i +2 ;
Thanks I did - but still the same error
foreach (N[i]){
if (i >0 && i < 30)
N[i] == i;
N[i+1] == i;
//i == i +2 ;
There are 2 other issues I missed ::
(1) Each bit of ‘N’ can be either 0 or 1 and you are trying to assign non-binary values ( 2 to 31 )
(2) There is a possible conflict when each index is being assigned twice
Eg: When i is 1, you constraint N[1] and N[2]
When i is 2, you constraint N[2] and N3]
N[2] is being constrained twice. If the constrained values are different there would be a conflict
Conflict at N[2]:
  • From i = 1, N[2] must be 1.
  • From i = 2, N[2] must be 2.
  • This is a direct contradiction: N[2] cannot be both 1 and 2 simultaneously. The constraint solver detects this inconsistency and fails, resulting in the “constraint inconsistent” error.
class fin_array;
constraint c_N {
foreach (N[i]) {
if (i > 0 && i < 9) {
N[i] == i;
N[i+1] == i + 1;
module tb;
fin_array f = new();
if (f.randomize()) begin
$display(“Randomization successful: N = %p”, f.N);
end else begin
$display(“Randomization failed!”);
class fin_array;
constraint c_N {
foreach (N[i]) {
N[i] == i;
N[i+1] == i + 1;
module tb;
end else begin
