Constraint randomization of an array
Thanks for the reply Dave. Oddly enough I cannot reproduce the error. It seems to be working. And thanks for showing how to shorten the constraint.
@dave_59, I am trying to randomize the array of any size. However I get compile error, can you please let me know where i am going wrong in this.
Here is my code :
class array_matrix #(M, N);   // generate a array of size MxN
  rand int array[][];
  constraint size {
    array.size() == MxN;   // size should be mulitple of the matrix MxN
    array.sum() with (32'(item)) == {[MxN]} ;  // sum should be = matrix MxN
    foreach (array[i][j])
        array[i][j] inside {[MxN]};  // each element should be inside the MxN var.
 constraint uni {
    unique {array[i][j]}; }  //have unique elements in the array
  function void print();
    foreach(array[i][j])
      $write("\n Array[i][j]=[%0d][%0d], ", i,j,array[i][j]);
    $display("\n =============================");
module const_ex;
  array_matrix arr1;
    arr1 = new;
    void'(arr1.randomize());
