Correct! I was solving for a problem which had 10 consecutive ones. Thanks for correcting
I tried the above problem as follows:
class abc;
rand bit[31:0] addr;
rand bit[31:0] shift;
constraint addr_c{
shift inside {[1:16]};
addr == 10'b1111_1111_11 << shift;
addr = ~addr;
$display("arr == %b shift =%0p", addr, shift);
endclass: abc
module tb;
abc abc_inst;
abc_inst = new();
repeat(10)
abc_inst.randomize();
module test;
class constraints;
rand bit[31:0] data;
constraint seven_ones_c{
$countones(data) == 12;
//Solution-1
constraint ones_c{
foreach(data[i]){
if(data[i]==0)
data[data[i] +: 9] == 10'b00_0000_0000; }
//Solution-2
//rand int start_index;
//constraint index_c{
// start_index inside {[0:31-7]};
//constraint final_c{
// data[start_index+:9] == 10'b00_0000_0000;
$display("data=%b", data);
constraints c;
c=new();
c.randomize();
