Constraining WStrb
Hi All,
I have a 128-bit AXI interface which supports Sparse Writes. Although as per AXI protocol each bit of WStrb corresponds to 1 byte of write data bus, in our case WStrb operates on DWord ( 32-bit ) granularity.
So essentially each 4-bit WStrb would be 4’h0 or 4’hF.
An additional requirement is that "strobes can’t be discontinuous meaning that we can’t have WStrb as 16’hF0F0" i.e we can’ have a 0 between 2 F’s
Eg: 16’hF0F0 would be illegal whereas 16’h0FF0 , 16’hFFF0 would be legal
Here is my attempt
task write_data_axi(input longint my_addr, input bit [127:0] data_in[],input bit[3:0] awlen,output bit[3:0] DWord_strobe[],input bit rand_addr = 1);
  bit [3:0]   Dword_strb[];
  if($test$plusargs("SPARSE_WRITES")) begin
     Dword_strb = new[4*data_in.size()]; // For 128-bit Wdata there would be 4 DWords, For 2 beats ( each of 128-bit WData ) there would be 8 DWords
      if( !( std::randomize(Dword_strb) with { foreach(Dword_strb[i]) Dword_strb[i] inside { 4'h0 , 4'hF }; } )  )
          `uvm_warning(get_type_name(),$sformatf("Randomization failed for Dword_strb"))
          `uvm_info(get_type_name(),$sformatf("For Sparse Writes,using DWord Strobe as %0p",Dword_strb),UVM_LOW)
     DWord_strobe = Dword_strb;
The above in-line constraint only constraints each nibble of WStrb to either 4’h0 or 4’hF.
I am seeking suggestions to constraint as per “strobes can’t be discontinuous”
One possible solution is that I have a queue ‘valid_q’ ( each element is 16-bit wide ) of all valid combinations and I constraint
 {     if( i % 4 == 0 )
        Dword_strb[i+:4]  inside { valid_q } ;
Any possible alternative solution without using non-random array ?
( Curious if there is a possible solution using iterative constraint like sum()/and() )
class non_sparse_strb;
rand bit  w_strb[];
rand int  valid_bytes;
rand int offset_start;
constraint c_strb {
                   w_strb.size() == 16;
                   valid_bytes inside {[2:8]};
                   offset_start inside{[2:8]};
                   offset_start + valid_bytes <= 16;
  foreach(w_strb[i]) w_strb[i]=0;
   $display("\n#########################################33");
 $display("\n valid bytes = %0d , offset = %0d", valid_bytes, offset_start);
  for(int i = offset_start ; i < offset_start+valid_bytes ;i++)
    w_strb[i] = 1;
function void print();
  foreach(w_strb[i]) $write("%0d ",w_strb[i]);
module tb;
 non_sparse_strb nstrb;
 nstrb = new();
repeat(5) begin
 nstrb.randomize();
 nstrb.print();
class non_sparse_strb models a non-sparse strobe signal (w_strb) that marks valid portions of dynamically sized data_in. The constraints ensure data_in scales between 128*1 and 128*8 bits while maintaining proper mapping to w_strb. valid_bytes controls how many dwords (32-bit chunks) are valid, and offset_start defines their starting position within bounds. The post_randomize function resets w_strb before correctly marking valid positions.
rand bit  w_strb[];
randc int  valid_bytes;
rand bit [127:0] data_in[];
constraint c_strb {
  data_in.size() inside {[1:8]};
  w_strb.size() == 4 * data_in.size();
  valid_bytes inside {[1:w_strb.size()]};
  offset_start inside {[0:w_strb.size() - valid_bytes]};
  w_strb = '{default: 0};
  for (int i = offset_start; i < offset_start + valid_bytes; i++)
    w_strb[i] = 1;
  $display("\n valid bytes = %0d , offset = %0d strb.size = %0d data_in.size() = %0d", valid_bytes, offset_start,  w_strb.size(),data_in.size());
module tb;
 nstrb = new();
  repeat(16) begin
   nstrb.randomize();
   nstrb.print();
rand bit [31:0] strb;
bit [32:0] strb_shift;
constraint cont_strb_cn {
$countones(strb_shift ^ strb) =< 2; // If more toggles are there in between it will be more than 2
function pre_randomize();
strb_shift = strb<<1;
