Constrained Memory Block Allocation
I am trying to generate a constraint to allocate a block of memory in a given address range. This memory block should not overlap with a reserved memory region. Here are my constraints -
rand int unsigned mem_addr_start;
rand int unsigned mem_size;
constraint block_size_c {mem_size % 4 == 0;}; //Making the block 4B aligned
constraint addr_start_c {((mem_addr_start >= 8'hE0) || ((mem_addr_start + mem_size - 1) < 8'h20));
                           ((mem_addr_start + mem_size - 1) <= 8'hFF);};
Now, with the above constraints I expected the mem_addr_start to fall outside 8’h20 and 8’hFF, which is my reserved area. However, I do not see this happening. Would like to know the reason why.
When I modify block_size_c as below, I am getting the desired result. Why don’t I get the correct solution without using a range of values?
constraint block_size_c {mem_size inside {4, 8, 16};};
Your constraint addr_start_c does not handle overflow. Use 33'h20 and 33’hFF.
I am trying to understand your response, Dave. It is not clear to me the situation which would result in an overflow. Could you please elaborate with an example. Thanks.
Display the results you are getting with
    $displayh(mem_addr_start,,mem_size,, mem_addr_start + mem_size - 1);
I got it. Prints did help to understand. Thanks, Dave!
