I have a reference model in my test environment that I want to upgrade. I want to add a component inside this class that is a model of some part of its logic. A simplified block diagram is shown below. Output of subRef is also an output of Ref Model.
- How should I create and use uvm analysis ports to pass data from subRef’s UAP to Ref’s UAP?
- What should be the correct way of connecting Ref’s UAPI to subRef’s UAP?
Note: Currently I am passing the data “manually” by calling subRef’s write_XXX method from Ref’s write_XXX method. They both need to be executed. However, they are independent of each other.
My goal is to update Ref model in such a way, that using Ref model requires connecting only its UAP/UAPI without the need of connecting subRef’s ports. subRef would stay “hidden” for a user.
Thank you for your time and help!
UAP - uvm_analysis_port
UAPI - uvm_analysis_port_imp_XXX
Block diagram. Before and after creating subRef.
I was able to answer to my first question - output ports. I didn’t expect that I can connect it like this.
class SubRefModel extends uvm_component;
`uvm_component_utils(SubRefModel)
// Input port
`uvm_analysis_imp_decl(_ctrl_in_port)
uvm_analysis_imp_ctrl_in_port#(ControlTrans, SubRefModel) ctrl_in_port;
// Output port
uvm_analysis_port #(DataTrans) data_out_port;
// Other lines: new, build_phase, etc.
class RefModel extends uvm_component;
`uvm_component_utils(RefModel)
// Input port
uvm_analysis_imp_ctrl_in_port#(ControlTrans, RefModel) ctrl_in_port;
// Output port
// SubRef
SubRefModel u_sub_ref;
// Connecting output ports is easy
u_sub_ref.data_out_port.connect(this.data_out_port);
I still struggle to connect input ports from Ref’s connect_phase.
Is there a way to get ctrl_in_port’s uvm_analysis_port it is connected to?
Something like:
this.ctrl_in_port.<SOMETHING_HERE>.connect(u_sub_ref.ctrl_in_port);
The closest I could get to ports provided to uvm_analysis_port_imp_XXX is this code.
Part of Ref’s class:
function void end_of_elaboration_phase(uvm_phase phase);
uvm_port_list list;
this.ctrl_in_port.get_provided_to(list);
if (list.size() == 0) begin
`uvm_error(get_type_name(), $sformatf("%s.ctrl_in_port c to any uvm_analysis_port", this.get_full_name()));
else begin
`uvm_info(get_type_name(), $sformatf("%s.ctrl_in_port is connected to d%0d uvm_analysis_port", this.get_full_name(), list.size()), UVM_HIGH)
I have tried to get uvm_analysis_port from list but I failed to find what method should I use.
[Q] Does anyone know how could I execute .connect(…) on element from list?
I think it should be something like this:
foreach(list[elem] begin
list[elem].<SOMETHING_HERE>.connect(sub_ref.ctrl_in_port);
