Confusing UVM_ERROR in uvm_reg_bit_bash_seq
Hello,
I don’t think this is an error because a value of 0 is being written and the yielded value is 0. So there should be no problem with that.
its depend on the permission of that register, this would be only true if register/field is RW in nature.
after looking into UVM_ERROR I believe,permission of reg/field is RO
so,
initial value = 0001
expected value after writing 0 on #0 bit = 0001 (as RO)
actual value which you got = 0000 (because of it got written on register #0th bit even though its RO)
if this is not case, please share register code for ‘MODE_SET1’
Regards,
Vinay Jain
