I tried various examples from LRM Section 16.11 for better understanding .
I finally get the reason you called the subroutine to increment variable ’ ticket ’
( As ’ ticket ’ isn’t a local variable it can’t be assigned within the property )
I have a few more questions to conclude the thread :: EDALINK
Via +define+M_A ::
**[Q1] Both the $display() execute in the re-active region .
Is there a predefined order in which the $display() ( within the property V/S within the pass / fail action block ) should execute ?
i.e Should the $display() within the property execute before the Pass / Fail action block ??**
[Q2] Can I say the following ::
(a) The assignment to local variables ldata take place in re-active region .
(b) The local variables ldata are assigned the preponed Value sampled for rdata***
Via +define+M_S ::
[Q3] I observe that $display() within the property reports different values than the $display() executed within the subroutine .
Is it cause the preponed values are used in $display within the property ?
[Q4] Is there a defined order in which the $display() be executed within the subroutine , within the property and the pass / fail action block ?
