Hi Dave,
Thank you for the response.
I am trying to generate the pulses within the rates of 1,2,5 and 10. I have written point wise how I tried to analyse the question and wrote the above code.
- function pulse_gen should generate the pulse at the rates specified
- class which will have the declaration of the rand variable rate and the constraint for rate
- module which should randomize the rate within the given values
- sending the result of randomization to the function pulse_gen which will generate the pulse
I didn’t have a specific signal as such, I want to generate the signal pulse which is more like a clock which has its positive level for less than 50% of the time period. Here I am trying to assign that clock period using the variable rate.
Just like #4 clk = ~clk
I want the # rate and would like to define the rate within some range or within some specific rates as mentioned in this question.
For the above code I have written, I am getting the following error.
Error-[SE] Syntax error
Following verilog source has syntax error :
“testbench.sv”, 21: token is ‘function’
function gen_pulse;
Thanks,
Sruthi.
