Clocking Block in UVM Driver
would there be any difference in the way it runs in the following two codes.
In code-1 , forver @(vif.cb) is used with while() loop
In code-2 , forver is used with do-while() loop
Which way is better with clocking blocks ?
Code-1
task run_phase(uvm_phase phase)
   forever @(vif.cb) begin
            seq_item_port.try_next_item(item);
           if(item != null) begin
               vif.cb.valid <=1;
               vif.cb.data <=item.data;
               while(vif.cb.enable == 1'b0) @(vif.cb);
               seq_item_port.item_done()
           else begin
                vif.cb.valid <=0;
               @(vif.cb);
code-2
   forever begin
               vif.cb.valid <=1;
               do
                  @(vif.cb);
               while(vif.cb.enable == 1'b0) ;
           else begin
                vif.cb.valid <=0;
               @(vif.cb);
I don’t see a clear preference of one over the other, however, there is a subtle/key diff in functionality - if the enable was high, code-2 would wait for a clock, code-1 won’t.
