Cast to parameterized variable fails
Thanks for the solution. I will walk through the attached article but,
How about the below implementation which makes use of polymorphism without interface classes?
What is the difference? How to choose in between?
module top;
      typedef struct {int A;} some_def_type;
      class A;
      virtual class abstract_policy#(type from_type, to_type);
          virtual function void copy(input from_type from, output to_type to);
	  virtual function logic compare(input from_type lhs, output to_type rhs);
      class policy_struct#(type from_type, to_type) extends abstract_policy#(from_type, to_type);
              to = to_type'(from);
              $display("policy_struct");
      class policy_class#(type from_type, to_type) extends abstract_policy#(from_type, to_type);
            $cast(to,from);
            $display("policy_class");
  class param_class #(type type_foo = some_def_type,
                    type type_bar = some_def_type,
                      type policy_t = abstract_policy#(type_foo, type_bar));
    type_foo foo;
    type_bar bar;
   	policy_t policy;
    function new();
      policy = new();
    function void some_func();
      policy.copy(bar,foo);
   param_class#(some_def_type,
                some_def_type,
                policy_struct#(some_def_type, some_def_type)) h1 = new;
      param_class#(A,A, policy_class#(A, A)) h2 = new;
     h1.some_func();
     h2.some_func();
