$cast failed when casting sequence item
casting failed in the below code. It was working and then started failing the casting(no change in this sequence) . what could be the issue to make the casting failed in this code?
sequencer also having same transaction type.
import xyz:: *;
class simple_seq extends simple_base_seq;
 `uvm_object_utils(simple_seq)
 `uvm_declare_p_sequencer(seqr1);
 xyz::simple_txn txn1;
 function new(string name = "simple_seq");
  super.new(name);
endfunction : new
 virtual task body();
If(!$cast (txn1, uvm_factory::get().create_object_by_name(xyz::simple_txn, simple_txn_inst1))) begin
 `uvm_fatal(get_full_name(), unable to cast ")
//assigning values to transaction item in txn1
The function create_object_by_name() has the following definition:
function uvm_object create_object_by_name (
  string requested_type_name,
  string parent_inst_path = "",
  string name = "");
The first argument ‘requested_type_name’ should be a string. In your code, it appears that you are passing a data type (‘xyz::simple_txn’). Is the code you posted correct? Or is there a typo? Also, the second argument is also a string, and the argument you pass also seems incorrect, although I don’t see ‘simple_txn_inst1’ defined anywhere.
