//To check duplicates in array below i have my code and i am getting syntax error.
and my doubt is can we iterate using “while” or “for” loop inside sequence?
array = {1, 2, 3, 4, 5, 4, 7, 8, 9, 10};
sequence check_for_duplicates;
int i, j;
// Loop over each pair of elements in the array
for (i = 0; i < 10; i++) begin
for (j = i + 1; j < 10; j++) begin
// Check for duplicates and ensure i is not equal to j to avoid self-comparison
if (i != j && array[i] == array[j])
disable iff (1) // Disable the sequence when a duplicate is found
$fatal("Assertion failed: Duplicate values found in the array");
endsequence
You cannot put loops or other procedural code inside a sequence. Sequences are temporal constructs for detecting changes over a period of time. Better would be defining a function and using that in an assertion.
function bit check_for_duplicates(int array[]);
foreach(array[i])
foreach(array[j])
if (i != j && array[i] == array[j] ) return 1;
return 0;
assert (!check_for_duplicates(my_array) else $fatal("Assertion failed: Duplicate values found in the array");
Hi @dave_59
In above code “return 0” is else part of fareach(array[j]) or foreach(array[i]).
Neither. It comes after both foreach loops terminate. Perhaps using begin/end blocks makes it clearer. But they are unnecessary when each block contains only one statement.
foreach(array[i]) begin : loop_i
foreach(array[j]) begin : loop_j
end : loop_j
end : loop_i
return 0;
Thank you @dave_59
i have got clear idea about my doubt.
